Hi all,
This is the mistery :
About a year ago I bought a 2005 C4S from a friend. The car was in excellent condition,13.5K miles,serviced at regular intervals,etc. I now have about 20K miles and other than a leaking RMS, now fixed, I've had no problems.
The car runs well,idles quietly and smoothly but it was sort of uninspiring under acceleration. I've done many Italian tune-ups, put injector cleaner in the tank, even used a tankful or two of 104 oct with only temporary improvement and then back to a sort of linear acceleration going thru the gears.Not much fun at all !!
Everything changed yest. When I got in the car after work, I accelerated as always but the car leapt forward and kept revving and picking up speed as if I had another 75HP, the way I always expected it to be !!! Today it has been a pleasure to drive it, stab the throttle and instantly feel the rush of speed.
Any theories to explain the sudden change?
911fan
It reminds me of the MAF sensor problem that i had in my toyotas. Sometimes it would throw a code and sometimes it wouldn't.
Those things are a pain when they start to go. Once i replaced mine, it was fine. I always try the least expensive things first. Clean the MAF sensor and make sure you don't use an oiled filter.
Hi all,
911fan
Edited by dallison
Hi dallison,
Thank you for the reply. I hadn't thought of that possibility. The car is running great right now so I won't mess with it but I'll keep this suggestion in mind
911fan
Hi all,
911fan
Hi 70Sixter,
Thanks for the welcome. I've been lurking on/off for about a year and learning about 996s. My previous Porsche experience is with a 911SC, now with a 3.6 conversion,gears,etc
Lots to learn about these water cooled cars!
911fan
:welcome: :welcome: 911Fan
Edited by 911fan
