I have a UK spec RHD 2000 reg Boxster 3.2s. The rear trunk / boot light doesn't come on when you open the lid. The lamp is ok and there is no 12v feed at the socket. Anybody got any ideas?
Cheers - Matt.
Check the fuse, check the light bulb or switch the light unit with the one in the front trunk. If it works in the front trunk then you have a faulty switch.
I had the same problem but in reverse (front trunk microswitch)...it ended up being the microswitch. Easily fixed....more time taking the internals off to get at it then actually replacing it. The rear is a bit easier. If after checking the fuse and you find it to be good (hopefully) then the switches are rather inexpensive.
Good luck...
m2
