Some of you who noticed in recent get-together drives, others, see if you can spot the difference between the taillights in the first pic:
No - not the silvervision bulb for the turn signals
Right - the left taillight glows with one more bulb:
Before:
After (the brake light is also on, ignore this left-most light)
Same on driver's side (no brake light, just running lights)
Mod is very simple, you need to
1) disconnect the fog-light position from the wiring harnass
2) reconnect (solder) the base of the fog-light position together with the running lights
3) change the bulb to a normal running light bulb.
Here you see the tail light insert after soldering, and hooked up to power:
Here, the same tail light insert at the left, the non-converted tail light insert at the right:
It's a very minor mod, but you have twice the light-output on the freeway, and redundancy - should one bulb fail.
You give up the fog light option, but I have never used this option in California. If you like to keep this, you need to do a little more wiring (need a two-wire bulb with contact points)
For higher resolution pics go to my webpage
This is cool. Now I need a work on cars day with 24hours for the long list of things I want to do...one more added...
Is there any chance of an electrcal problem if you were to switch on the foglights?
Not at all - in my case I ended up taking the pin for the fog light out of the connector. That way I can solder the lead to the lamp to the running lights (rendering the fog-light switch useless).
If you would like to keep the foglight feature, you can opt for a double-pole light bulb (both brake/fog and running light) and you have to make the harnass fit this. It is technically not too difficult, you just have to figure out how to make a custom harnass.
Edited by HenryV
