Hello All,
I have an '05 Boxster S with about 46K miles on it. The car was built at the Stuttgart plant. I had the AOS and water pump replaced last week and a day after getting it back the car began to pop out of second gear on deceleration under load like before taking a corner at speed. It seems to only happen on deceleration and occasionally when I lift after acceleration. No grinding when I shift up or down just the pop. It did progressively get worse over the last week. I have began just skipping second when I downshift. It still shifts up though all the gears fine no grinding and no pop even under hard acceleration. I saw many posting about this subject but not one that fit so before I go spend $3k I thought I would post. Any advice would be much appreciated...
Andrew
This is almost always due to an internal problem inside the transmission, likely due to worn dog teeth on your gear and your syncho hub.
Took it to a mechanic and he tried everything he could think of up to opening the transmission. Dog teeth it appears to be got a quote for about $2600. Thanks for the reply.
Edited by andrew_box
Took it in to get the tranny rebuilt and was told that it needed a new one. The mechanic got one for $3000 and another $500 to put it in. While he was in there he said the clutch had about 5K miles to go and he would do that installed for $1100 RMS for $80. Also got the shoelace problem fixed p/l $300 and a dollar size door ding $125. All total $5240 and the car never ran so good even better then when I bought it.
Sounds like you got off cheap. What's the "shoelace problem?"
Cheap I guess could always be worse...
The shoelace problem is explaned here with a fix and pics:
http://www.renntech.org/forums/index.php?/topic/18621-top-issue-any-idea-what-this-snapped-string-does/page__p__94962__hl__shoelace__fromsearch__1entry94962
