My rear cup holder won't stay closed. I am guessing it's broken and can't be fixed. Does anyone know how to remove and replace it? Just want to make sure I don't break anything else.
Pull out the cubby that's right above it. You can just pull it straight out, a small screwdriver will help you pry it out. Once that's out there are two spring clips on top that hold it in, one on each side. Press the springs down and pull the cupholder out. Cheers if you can figure out how to fix it.
Edited by PTEC
