Your Cayenne should do it if you just turn the mirror adjustment knob when you park. Mine does. While that is not totally "automatic", it only requires that you turn the knob when you turn the key off to park.
Seems simple enough?
Not aware of any that just know you are parked and retract? Maybe someone else does.
DC
DC
The mirrors on the newer MB models can be set to retract automatically when you lock the doors after parking. They return to normal driving position when you unlock and open the driver's door. It's a nice feature that doesn't require a separate action to implement.
