I've read on a few websites that the pre-2000 996 and pre-2000 Boxster transmissions were, with the exception of the ring and pinion and the extra gear, essentially the same. Is this true?
Are the gears stronger? Any other parts stronger? Would there be a way to rebuild a Boxster transmission with the stronger components that a 996 has (not the actual components from a 996, but do they build stronger Boxster components?)
They might be stronger... I do the know ring gear in the six speed is significantly larger. Its not like you see a lot of shredded boxster tranmissions though. What is the concern that that the stock 5 speed isn't strong enough?
I dont know how much work it would be but what about installing a boster S transmission?
