have a 99C2 Cab and 03 C4S,the coolant tanks on both are below the mininum mark but there is a little coolant in them,both have the yellow green stuff,what is the best collant to add to top up,i have read that you cant mix the pink stuff with the yellow green because it will turn to gel but you cant get the grren stuff anymore,what to do
Albert
There are as many opinions on Anti-Freeze as there is oil! I recently flushed my system, replaced water pump, hoses etc. and used Porsche coolant. You can get it from Suncoast Porsche for $20 a gallon. While I have no doubt that other products work just as well I chose to use the OEM recommended coolant. As long as you don’t mix types you should be ok. However, if you didn’t buy the car new then you really have no way of knowing short of sending off a sample for analysis. And, at that cost, you might as well just replace the coolant. Hope this helps. B)
Coolant for your Porsche is pretty cut and dried. Only use a G-12 type coolant. If you don't want to pay the Porsche parts counter price for a gallon, then go on down to your VW dealer's parts counter and get it there.
