Hello -
This is my first post,so I hope I am doing the correctly. I have a 1999 5-speed Boxster. I have a check engine light code of 1691, the
mechanic said I had to replace the entire instrument cluster to fix this problem. Does this procedure seem correct.
Hello -
P1691 is usually either a short or lack of continuity between the DME and the instrument cluster, or a lack of ground at the cluster. While it could be the cluster itself, it rarely is, more often it is a wiring issue…………
