2003 Boxster S.
I am not able to identify what some of the tools are for in the tool kit that comes with the spare tire. There is the tool for removing the lug nuts, a tow hook, but there are some tools that I have no idea what they are for.
One tool looks like an 8mm hex wrench which I assumed would be used for the oil drain plug, but when I tried to fit it into a spare drain plug that I have it would not fit.
Another tool is about 8 inches long and has a threaded end on it. It is probably about 1/2 inch in diameter.
I will try to post a picture.
2003 Boxster S.
You will need the smaller hex nut to unlock the headlights to change a bulb. It's in the owners manual. If you don't have one, this site has a 2003 that you can download.
The long tool that is 8 inches long goes into the wheel when you are taking it off. It acts like a guide for removal and replacement of the wheel and tire. So you don't mark up your calipers.
