Does anyone have a copy of PCM install instructions for latest version?
i just received 08.2009 updates for my NAV.
came with 3 discs:
1. Map DVD
2. PCM 2.1 Multimedia Update CD Cayenne
3. PCM 2.1 Multimedia Update CD Navigation
thanks
matt
came with 3 discs:
1. Map DVD
thanks
matt
With the car running, i believe you remove your old Nav DVD, then Insert Disc 2 in the Head unit till its done, then Disc 3 in the Head unit until done, then place the Nav DVD in the DVD drive.
came with 3 discs:
1. Map DVD
thanks
matt
Remember that DONT TURN OF THE POWER when the PCM is updating. Doing so will cause software error and you need to replace the PCM.
Keep us updated on how it went.
A couple of questions;
bWhat Year Cayenne?
What Version PCM?
Do you have the part number of the Updates?
How Much?
Where did you get it?
