I just purchased my 3rd 997.1, this time an 06 C2S cab. I've noticed that there are under-dash lights over both the driver and passenger footwells, but neither comes on when doors are opened. I can't remember if my previous cars had these lights. Are they supposed to illuminate when doors are opened?
i would sit in your car with the door open and look at teh overhead switches in the dome light. there is a set that will control if the footwell lights come on when you have the door open. i think the middle position is automatic and the left/right toggles turns them off or on manually.
thse are seperate from the individual driver/passenger light switches
  • 4 weeks later...
Bingo. I had set the 2 outside rocker switches to the middle position, but had overlooked the center rocker switch. Once it was set to the middle position, the footwell lights came on.
