Thanks for all the help with my spark plug issue the coil boot on 2 plugs were loose runs and sounds great but the cel is on now why would a plug remove and replace cause this.
You'll need to read the codes to see what they are....
I don't know the history -- but it is possible that that CEL is response to previous issue -- possible to clear and see if it reappears.
Also double check your work -- making sure that the plugs are properly torqued, all connections are tight.
Unlikely and just a WAG, but did you use the proper plugs -- possible wrong plugs may have it burn lean or rich due to level of spark?
m
