As the top says, coming through the wheel and through the 'back-end' under hard acceleration.
I presume it's a matter of elimination, but my questions:
-Could bad alignment cause this?
-Could a worn rubber bush in a suspension component?
The wheels have recently been balanced, so not an issue when keeping a constant speed.
Cheers
Could be a lot of things. Even bad motor mounts.
What year is your car? Mileage?
Have someone drive behind you, and accelerate. Do they see your exhaust tips dip up & down? If so, it could be worn motor mounts.
Cheers
Gary:
You didn't say how much mileage and what year Boxster, but one easy place to check is the engine mount, a common failure point.
Here's a link to Pedro's Garage page on inspecting and replacing the mount: http://www.pedrosgarage.com/Site_3/Install...gine_Mount.html
Let us know what you finally determine as the cause.
Regards, Maurice.
Based on your conditions I would bet worn motor mounts too. If it was an alignment issue you would only feel a pull depending on camber/caster/ or toe issue....And if it was a balance issue you would get a shake most likely...more pronounced in the 50-60 mph range, but not related to acceleration. Also with worn suspension bushings, you would most likely get a shake, or clunk all the time.
So I agree it is likely motor mounts.
Good luck!
DC
Edited by therock88
Thanks All - The car's a 02 986S with 114K now, so most things will start to perish :)
Will definitely check the mount tomorrow - but would/should it manifest itself in other ways, such as should you be able to feel it when dipping on and off the throttle?
Edited by Gary H
Had it up on a ramp today and as suspected, the front engine mount was completely fubar.
Thanks all!
Gary:
Glad you sorted it out, and thanks for confirming our suspicions!
Regards, Maurice.
  • 9 years later...
Was it the engine mounts?
I have the same problem on my 986S, and replaced the engine and trans mounts. They were worn out, and needed replacing anyway, but didn't fix this problem.
It's definitely not a buckled or unbalanced wheel either.
Any other suggestions?
Thanks.
