Front radiators full of road debris, coolant reservoir leaks, grease stripes on front door windows, minor oil leaks, MAF issues with oiled air filters, automatic spoiler issues, smoking on start up.
Sounds worse than it is. Most everything is minor unless it's been flogged.
BD
Clutch slave actuator. door window regulator, oil pressure transmitter, Stay on this site for info how to fix those. You will found some valuable info and a lot of nice and helpful people....
Of course if you get on these sites, you will find problems. How "typical" the problems are is another question. Here are some things to consider:
1. Power steering reservoir (TSB)
2. Ruptured fuel lines and fuel pump
3. Key FOB
4. Maf
5. O2 sensors
6. Coolant cap
7. window/door electronics
8. Battery
Others I've had replaced under warranty: Nav system, Alarm module, Front differential
