i replaced the plugs and cleaned up the coil packs. After i fired it back up it was running rough and the cel came on. It tells me that cylinder 3 is not firing correctly. Which is cylinder 3 so i can check that one?
found it, passenger rear. I just need to learn the keywords to search for...
i ran out and checked, the harness connection came off the coil pack. I could have sworn that it clicked the 1st time. runs fine now.
Edited by dallison
