I need to replace the front drop links on the front stabiliser on my 98 996 C2. I slackened off the bottom 15mm bolt (drop link to stabilizer) and disconnected that end of the drop link from the stabilizer. I slackened the larger bolt on the suspension strut (the upper threaded part of the drop link appears to clamp the whole wheel hub to the suspension strut?) I backed the nut all the way to the end of the thread and then gave a few taps with a hammer but the drop link wont budge?
Once the top nut is off is it just a case of applying a bit of force with a hammer to drive the threaded shaft out of the hub or does the top connection need to be unscrewed from the hub (there is a hex right next to the balljoint which can be gripped with an open ended spanner)
