When I ran the ABS test under Durametric, there was a "ABS failure" displayed briefly on the cluster then disappeared, there was no errors in fault memory regarding ABS reported by Durametric though. I assume this was simply a jitter caused by running the test?
I suspect so - I recall getting the same error on my PST2 when I run that test.
My guess would be that it needs to reset the controller during the test.
The ABS alert happens to warn you that some the ABS system might not function correctly while being interrogated by diagnostic software during a road test.
