Hi
1999 C2 coupe, USA 51,000mi
I've had my car for almost a year and my aftermarket warentee is about to expire. Given that many here have had mixed results with warentee providers and the expense of a new one, I'm probably not going to extend it. My main concern is catastrophic engine failure
I have no RMS or IMS leaks and the car has been a solid runner so far, but I suspect it might need a clutch soon since I'm getting a little chatter once and a while.
I have two questions for any that have an opinion:
1) Do you think it is worth doing a IMS retrofit kit and a RMS as a preventative measure when putting a clutch in? I know very little about the maintenance history of this car.
2) Does anybody here know of a good independent shop in the Cherry Hill area (Southern NJ, USA) that would be familiar with the proper installation of the LN engineering kit? So far I've had all work done at Cherry Hill Hill Imports, which is my local Porsche dealer. I'm not sure they would put in a non factory kit even if they know how.
Thanks in advance
Doug Davis
You need to contact Jake Raby at Flat6Innovations. He answered a similar question on this or another forum. IIRC there is no one in your area, and Jake ain't lettin' no shoddy shops ruin his rep.
Basically I believe it is good preventive medicine and will take my car to North GA as soon as I can afford the $3500 IMS upgrade/clutch replacement.
Jake does not believe R&R of engine is worthwhile w/o doing the clutch.
Hi
Thanks in advance
Doug Davis
My car, 107,000 miles, not one problem. No leaks. No nothing. All in a sudden, intermix... cracked cylinder and head... right now at shop doing engine rebuild.
Things happen. the 99s have the issues that they have. You will purchase some peace of mind, regarding IMS and RMS. Remember, though, that you still might experience cracked head/cylinder, which you can also address with Nickies and new pistons. But at this point, you are looking at an over 10k bill, practically a new engine.
Contact LN they answer the phone. They work with other people and they acknowledge it, although yes they have a partnership with Flat6.
Don't know anything relating to your second question, but as far as changing the Rear Main Seal and Intermediate Shaft Seal while you are doing a clutch, I would say absolutely! The labor for the R&R of the Engine and transmission are most of the cost. The approximate cost of the needed upgrade (which is several redesigns at this point) is about $125.00. There are updated pan screws, seals, and rings that with the latest version seem to be pretty solid. After about 6 tries it appears that they finally got it right!
So for ~$125 additional parts and just minor add'l labor, I would definitely replace.
Good luck!
DC
Edited by therock88
If you upgrade to tne L&N Engineering IMS seal, the cost of the seal alone is $595 plus RMS and incidentals, probably more like $750. I am doing it as soon as my CPO is done.
Not sure what the L&N Engineering parts are. To be clear, my information is based on OEM Porsche parts. Total is for all parts and includes:
900-067-369-09 screws
999-073-091-01 screws
997-101-212-01 Shaft Sealing Ring
996-104-215-54 Cyl Head Cup Seals
900-123-147-30 Seal Ring
900-380-019-02 Hex Nuts
999-385-004-01 Torx screws
900-385-275-09 Torx screws
996-105-017-02 Shaft Base (most expensive part at $62.75)
Total@ OEM Cost = $130.56
Have no info on L&N.
Having had the IMS inspection and seal replacement performed, I can tell you that it did give me piece of mind (I chose not to upgrade the IMS). Note that the risk when working with the IMS is that you may need to reset the cam timing, which can increase the repair cost quite a bit. Good luck.
