Hi all
just bought cayenne S from 2003, seller provided me with 2 remote controls for doors, and 1 for parking heater, but i can not find any manual on how to use this and wanted to make sure it is the right remote control.
does anyone have a picture of this to see if the 3rd remote is the right one? thanks for your help
Hi all
I have the same problem and nobody can help me, including the authorized dealer.
To couple the remote control with your parking heater, you should do this (from an original Webasto manual):
1) Install batteries in the transmitter
2) Remove fuse number 2 from the left dashboard fuse box in your Cayenne
3) Wait for at least 5 seconds
4) Refit fuse in the fuse holder and presss OFF button on the transmitter for at least one second within the next five seconds (talk about complicating stuff ...)
This should do the trick, but it doesn't work in my case. My parking heater works fine when I program it or start it from the car but I can not use the remote control.
So good luck and please let me know if you get any more info on this annoying issue.
i am living in Geneva, not so cold, so i will try this, and if it does not work, i will give up, dont really need parking heater, but just wanted to make sure what was this 3rd remote control?
