I have noticed with my 99 996 that everytime I shift from park to reverse or park to drive that the passsenger side rearview mirror is activated for parking positioning. The problem is it doesn't reset all the way up into the original position. Is this a common problem and is there a fix?
Thanks in advance, Dave
On my BMW this feature is controlled by the mirror selector adjustment switch. See if it still does the same with the other side selected. If it is on the left then try leaving it on the right the next time you shift gears.
