On both sides, the ABS trim piece underneath the front doors is loose. I removed the one on the passenger side and it is (no: was) attached with 4 white nylon rivet type pieces that attach the the body to which the molding piece then clicks onto.
A google search related to the actual trim piece (7L0 835 538 (also used on the Touareg / Q7?) did not result in anything useful so I am hoping anyone can chime in. I need 8 new nylon pieces to properly attach the trim / molding again.
JP
