Yes and no.
The Turbo uses the later style Bi-Xenon headlights. The MY02 and newer C2, C4, C4S uses the same headlight as the Turbo. The older C2 and C4 use the earlier Litronic headlights.
The "bi" in bi-xenon means that both the low and high beams are xenon.... right?
Correct.
In the older Litronics system the low beam is Xenon and the high beam is a mix of both the low beam Xenon and high beam H4 bulbs.
Correct.
That was what I thought... but my high beams don't seem to have the same 'hue' - or intensity - of the lowbeams, which are clearly xenon.
