Does anybody with PIWIS knows if there is a setting to enable push button on the trun signal stalk after retrofitting voice control? i have voice control functions on PCM on put new lever with button but pushing it doest activate anything. is there a setting that i have to do through piwis? thanks in advance.
  • 4 weeks later...
yes, went to the dealer today. the column has to be programmed to enable voice control button.
P.s. on a separate note that function produces some hilarious results
