Okay, I have tried searching and have had no luck. I replaced the stock radio/nav with an aftermarket and I have the SMA to antenna cable adapter but I don't know which SMA to connect it to. I have three that hooked into the stock PCM (2004 Turbo Cab with MOST system). I think one was yellow, one was black and one was blue? Not sure. I assume one went to the GPS antenna, and one went to the radio antenna, and the other ??? So which one does it hook too?
Thank you again for all your help.
-Matt
