My 04 CS, has a couple strange issues, not sure if they are related. I've read all the posts and scoured the net with no luck to fix. The Tiptronic shifter only works about 1 in every 5 starts on the selector lever, the steering controls work just fine. As well I can't remove the key when I turn the car off, this is also intermitent, it seems not to activate the steering wheel locks, you can hear it when it does then it releases the key. I have to turn the ignition to the on position then back off to remove the key and on the dash it asks me to place in "P" and turn key left 2-seconds.... taking the advise from the local Porsche dealer they replaced the shift gate, socket and cover... not cheap. Still no resolve, they have no clue so I'm hoping someone here has had this happen. I've read batteries may cause strange gremlins but I'm thinking something is screwy with my Kessy and wondering if there's a software falsh upgrade I should consider and how can I find out what version I have and what is the latest version. If I were to book another call when the PIWIS is installed to do the check does it automatically update the factory software?
The gear indicator on the dash and on the shifter should be synchronized, 1) shift cable misaligned 2) one of the sensors inside the shifter lever mechanism disturbed or faulty. If your dealer can't fix it, go to an OPC.
