Is it usual to have to top off oil in my 997.1 S Manual '06 with 40k miles?
I seem to have to add a quart every month or so there are NO OIL leaks while sitting. I park in the same spot at work,
and nothing in my garage. Just wondering if this is usual for a Porsche of that year.
:thumbup:
Thanks in Advance
Not sure if this helps, but the owner's manual seems to indicate some normal consumption is expected and varies based on conditions (including your driving style and oil used).
I realize your car isn't brand new, but here is some verbiage from the manual that would appear that you are OK.
Engine oil and fuel consumption During the break-in period oil and fuel consumption may be higher than normal.
As always, the rate of oil consumption depends on the quality and viscosity of oil, the speed at which the engine is operated, the climate and road conditions, as well as the amount of dilution and
oxidation of the lubricant. Make a habit of checking engine oil with every refueling, add if necessary.
Engine oil consumption up to 1.5 liters/1000 km
(1.6 quarts/622 miles)
It is normal for your engine to consume oil. The
is operated, the climate, road conditions as well
as the amount of dilution and oxidation of the
lubricant.
If the vehicle is used for repeated short trips, and
consumes a normal amount of oil, the engine oil
measurement may not show any drop in the oil
level at all, even after 600 miles (1,000 km) or
more. This is because the oil is gradually becoming
diluted with fuel or moisture, making it appear
that the oil level has not changed. The diluting
ingredients evaporate out when the vehicle is
driven at high speeds, as on an expressway,
making it then appear that oil is excessively
consumed after driving at high speeds.
If the conditions you drive your vehicle in are dusty,
humid, or hot, the frequency of the oil change
intervals should be greater.
If the vehicle is driven at a high rate of speed,
climatic conditions are warm, and the load is
high, the oil should be checked more frequently,
as driving conditions will determine the rate of oil
consumption.
It would seem that you are fine. Depending on conditions of inner parts, it is possible that some wear could be causing increased consumption, but you seem to be in normal range here based on the
limited information.
Hope that helps.
DC
Great info and :thankyou:
lubricant.
consumption.
Hope that helps.
DC
