I'm installing the glass window top from EZontops, on my 99 boxster. So far so good except I can't get the front part of the cloth to stick under the header bow. Has anyone done this, or have any idea what type of glue to use?
Could you explain in more detail which part you are referring to?
In a normal install, no glue or adhesive is required except for some double-sided tape.
Regards, Maurice.
Have you checked this description of the process: http://sites.google.com/site/mikefocke2/replacingthetop-adiy
I've been studying it and trying to determine whether I have the skill and patience to complete the job.
Kevin:
You are correct in your assessment that it requires a combination of skill and patience.
If you have a little of the first and a lot of the second, you can definitely do it.
If you run into any roadblocks, don't hesitate to ask and we can walk you through them.
Regards, Maurice.
