I have a 2006 Cayenne S and did the first brake rotor and pad job at 22,000 miles, I am now at 37,000 miles and wondering how far off I am again from repeating this expesnse and if early pad replacement may keep me from having to replace rotors again.
Can someone please confirm that the
V8 Brake disc thickness, new
front - 34 mm
rear - 28 mm
Brake discs minimum thickness
front - 32 mm
rear - 26 mm
Does anyone know what the new pad thickness is (material excluding metal pad backing plate). I realize its 2.5 mm before you hit the wear sensors, but want to know how far I have gone over the last 15,000 miles of driving.
VMAN
Loren,
Thanks for the confirmation on rotor thickness. Any idea about pad thickness?
VMAN
