What is the proper way to check the oil dipstick. After warming car, letting it sit, have on a level ground, pulling the dipstick out and cleaning it, and then returning the dipstick back, then how far do you go back into the dipstick tube? 1. All the way until it goes no further to the end of the clips (in running mode) or only to where the rubber "o"ring meets the tube? The manual says to the "stop", whatever that means.
