Thanks to Mile Poultre, here's how to remove the leather from factory sport seats (not the shell type) in preparation for painting seat backs.
1. Remove leather from plastic sport back.Start at the bottom corner towards door sill.(pulls out without any tools).This will take only the outside of the leather off.
2.Remove the foam horseshoe.
3.With the foam removed.You can see the leather clips that hold the leather from the inside now.Remove the leather section.
4.Remove the center section.It has 2 clips on the bottom that clip over 1 of the steel support bars in the seat.The top is held on with 3 leather clips.
5. Remove the 2 plastic knobs on the seat that allow it to fold.
6.Remove 4 screws that hold the plastic back to the metal frame.
7.Remove plastic seat back.
8.Remove map pocket.
