Hello Everyone,
Hoping someone can help a noob.
I find that when my 996 c2 alarm is engaged and someone tries (say) the drivers door handle, the next time (could be a few mins later) I disengage the alarm the drivers door will not open (from the inside or outside).
You have to get in through the passenger side, put the car ignition on and put the door lock on, then unlock it with the internal handle.
The issue also happens on the passenger side.
Is this a known issue?
Thanks in advance.
Steve
MY? Check alarm faults with PST2/PIWIS or durametric.
Thanks for the response - the car is a 1998
I'm guessing a specialist will need to check those fault codes?
