I just bought a 06' Boxster S and am wondering what are the real differences between the S verse non-S beyond the... generic... its stiffer, more rigid, e.g. they boasted the Springs to xxx, or they increased the mm of the sway bars, or they added xxx suspension components...
Thoughts?
Assuming you have a standard spring set up and not the optional PASM , the anti roll bars , spring and damper rates are all different between the two models. The gearbox is also a different beast and I believe the final drive may also be a differnt ratio. There was a dealer tech guide outlining the differences posted on the documents section of the forum.
Edited by berty987
