Hi guys, Im running a 2004 "S" manual UK car with 22000 miles on the clock. I have had trouble free motoring for the past 2 years. My problems started a few months ago when i started my car after a week sat in the rain. As i was pulling away in first gear the airbag light and interior light and passenger door light came on. After restarting the car the lights went away. This happened 2 or 3 more times early November and has not reoccurred since. I am now however experiencing difficulty starting the car every time i go to use it. On the inital turn of the key the starter wont even engage. If I turn off the ignition and try to restart it starts straight away. Sorry for the long post guys but im new to all this and would appreciate any light you may be able to throw on the problem.
Thanks in advance...
Check on this forum for ignition switch replacement. That's definitely your problem.
+1 on as per Blue2000s says.
And also make sure your battery is in good shape - if its an original and with the cold weather you are having in the UK, it may also be time for a replacement or at least an overnight 12 hour charge.....
Cheers guys I had an idea it may have been the ignition switch, i think i'll take it out to see which one ive got as im led to believe there are 2 types???.
Thanks for your help!!!!
Yes, two types. The older or original ones are black, and have an Audi/VW part number, Porsche no longer sells them, and the new style that is white. Not sure of the changeover year, you could pop out the heat duct over the driver's feet, and look up at the switch. The switch is on the forward end of the portion where you stick the key in, the elecrical part at the end will either be black or white. The two electrical portions are not interchangable.
The other thing that jumps to mind
since you mentioned rain is the drains got clogged and water got in under the passenger's seat (UK) and shorted out the alarm control unit. I'd be inclined to suspect that even more than the ignition switch since the symptoms track the rain report and the alarm lights.
You'll have trouble debugging because the wet may have dried by now leaving just a bit of corrosion between the wires going into the unit and the control unit itself.
The rear drains are the suspects.
Cheers Mike, I have been aware of the control box problem for some time after reading a number of posts on the subject. I always check under the seat and have never found it to feel wet. I also maintain the drain holes so fingers crossed I wont suffer this problem. Is there anything you can do to safeguard the control box ie(waterproof it) as prevention is obviously better than cure.
Thanks again.....Kenny
I've read of people who take the seats out, then the alarm control box out and they cover the control box in a plastic bag before reinstalling everything.
Not the best place for it, is it.
