My 996 C-2 has 52,000 miles and the front pads are getting close to the wear limit. I want to change them before the light triggers.
The rotors are at 26.873 mm (1.058 inches) and 27.0256 mm (1.064 inches). I know the minimum limit is 26 mm (1.0236 inches) and they come new at 28 mm (1.1023622 inches). 2 mm between new and the service limit is a relatively small window, but I have been able to go 50K+ miles so far.
Should I replace the rotors with the pads or just the pads?
Thanks for any input.
(I inadvertently posted this in the 997 forum)
