Hi thanks for any advice. Firstly, about a week ago the drivers window started making a very audible rubbing/scratching sound when raising or lowering. There's no mark on the window,but somethings wrong.The other thing started about two days ago.( With the door closed) about 2 seconds after the window reaches the top, it drops about 3-4 inches then stops. To keep the car secure I can edge it almost to the top and it stays there. Don't know if the problems are related. Any ideas?
Cheers,
Jason
Cheers,
Jason
Jason:
Your first issue sounds like a fraying window regulator cable. As Richard says, there's lots of info on this topic here (it's a very common problem), including a few good DIY posts on how to remove and repair.
regards, Maurice.
Cheers,
Jason
Jason:
regards, Maurice.
Thanks Everyone!
