I am the area needed to bring an external wire from the engine bay to the interior of the car (exposure of the rear grommet) - see picture.
The area circled in red is the safe grommet to poke through correct?
Once I make a slit and feed a wire feeder through - where will I end up in the engine bay?
I plan on feeding a wire for a radar unit from the rear license plate area to the interior. What's the best path to take? Do you eventually go behind the heat shield that seperates the rear part of the plastic bumper from the engine? In orther words, what is the best route from the rear grommet to the externeal license plate area?
Addtionally any suggestions on routing the wire from the rear grommet to the dashboard area?
Follow the wiring the hugs the console?
Other paths to follow?
Lift up the carpet? If so any tips on doing it?
This path? (not my car in photo)
