I decided to replace my becker with an aftermarket unit form JVC. I installed the unit no problem but I cant find a switched lead for the deck. The harness that Crutchfield sent works as it should except the yellow wire that normally provides the switched lead is not working. The guy at crutchfield is telling me its because of the most bus. So here I sit with my stereo laying in my seat and no power. Anyone know of a solution to this problem.
Will
Will
Member Rahlstrom installed a AVIC D-3 in his MY03 Boxster S with MOST Bus. Let us know how you progress. Good luck.
Press Here for Post
Thanks for the link but what he uses for the switched lead I am not sure where to find it or if I even have one in the car.
