Hello,
How much Coolant is there to fill between the min and max mark ?
Best Regards !
Happy new Year !
Edited by Boxsters
Hello,
Best Regards !
Happy new Year !
I just did this actually. It's only 1 Quart, the same size of bottle that you use for motor oil.
Hello,
Best Regards !
Happy new Year !
If you are not using coolant, be sure to only use distilled water!
Regards, Maurice.
Should be 50-50 water and silicate-free coolant. Test engine mixture with hydrometer. Max 60% coolant takes you to -40F.
