good question, I was wondering the same thing.
Also, the protective screen can be removed ? there are some strange spots under the screen, looks like dust or something... <_<
Hi!
Is it possible to change the luminosity of the PCM screen? make it brighter?
Ian
Which version of the PCM? On PCM3, it's the following sequence:
INFO->OPTION->SET PCM->Display->Display->Brightness. Then use the up or down arrows to set your brightness.
In PCM2, it can only be done in the Map Mode. See the attached file.
(PS - If you become a contributing member here, the Owner's Manual is available for download.)
PCM_2_Display.pdf
Edited by DUTCH VanAtlanta
Hi!
Ian
Thanks for the instruction, it's working now.
