Got an error code P1128 and P1130, car runs rough, when i press the gas pedal it starts choking, P1128 say Upstream HO2 Sensors Swapped and P1130 Lack Of HO211 Switches-Fuel Trim At Limit.
P1128 Oxygen Sensing Adaptation Area 2 (Cylinders 1 - 3) - Rich Threshold
P1130 Oxygen Sensing Adaptation Area 2 (Cylinders 4 - 6) - Rich Threshold
The DME thinks you are running too lean and it made the mixture as rich as it can and it is still too lean.
This means you have an air leak.
Either a fitting on or around the throttle body, or a bad AOS, oil filler tube, oil filler cap, or AOS bellows.
You need to do some further investigating...
Thanks for the reply, I will check and and post. Vic
Most probably faulty MAF sensor. That was the problem on a 986 I used to own.
