When I fully accelerate, kick-down, the turbo gauge shows about 0,4 - 0,5 bar... but it reads up to 0.8.
Does it ever go up to 0.8, or more than 0.5 ? how, when ?
Re, "nobody?"
Umm, it is a holiday today in the US...
I have a Cayenne S, no turbo (obviously) but I'll ask my brother-in-law later who has the CTT.
Try launching in first gear (versus second -- move your shifter left into manual mode) from a dead stop on a slight uphill. With the accelerator floored go to redline -- see what your boost is right up to and immediately after the shift into second. You should see maximum boost reflected on the gauge.
Edited by odix
from memory, the highest I've seen it under full acceleration is 0.6 bar; when gear shifts occur, it does peak higher
Maybe it's fuel related - this was with 100RON fuel in the UK ?
Under full acceleration I regularly see 0,7 on mine (05 model). If yours does not hit 0,7 maybe your diverter valves are not working properly? I think 0,7 is the factory max...I could be wrong though.
I see about .6 - .65 but never .7 and that is on 93 octane, in cool weather...
Under high load, up hill i'll hit .65 and it comes back down to .6 pretty quickly - I'd like to attach a mechanical gauge as well to see how accurate the electronic dash gauge is...
  • 7 years later...
22 minutes ago, fireflyer said:
I  see .8 regularly on my 06 CTTS, 93 octane.  104k miles
Old post but yes E81 power pack and ctts have 0.8bar as opposed to 0.6-0.65bar for ctt. This is the main reason for the 50-70bhp increase the E81 and Ctts have over standard ctt.
 I see that many people think that they should see a specific boost level in the Cayenne depending on which version/tune they have.
This is not the case. The Motronic 7.1.1 DME is a torque/load based system in which the DME is always trying to achieve a torque request target. There are boost tables that have preset limits based on what the manufacturer/tuner knows is safe for the engine combo. However, the short answer is that with so many variable on a day to day and region to region basis, boost levels will vary to hit the requested torque in any given situation- to a limit. With that being said, there are many variables that can affect boost pressure aside from requested torque.
