Okay, i've been having this occur for the past year and wasn't sure what was going on. But I"ve isolated the noise. Here is the run down. Lets say i'm at a light resting on a slight hill. Foot on the brake. If I lift off the brake while depressing the clutch and engaging first gear that is when the clunk noise occurs. It happens when the car is in slight forward movement from a braked stop to gear. The noise does not occur on a stand still situation. IE, foot never leaving the brake, or a level surface while shifting into first. Any thoughts on the culprit?
1999 C4 Manual trans
Edited by bmohr
