Noise is from engine/transmission for sure. Happens intermittently and usually when car is warmed up and underload when clutch is being disengaged at the take-up point. Lasts only a fraction of a second but quite annoying. Sounds exactly like when you walk on old/loose wooden floor.
Could it be the clutch slave cylinder?
Thanks in advance!
2003 C2
More likely the pedal linkage under the dash.
I would try some white lithium grease there first.
Hi Loren,
Happy Holidays!
Unforatuntely, I'm sure the creaking noise is from the engine/trans, under the car, and not anywhere close to the pedal.
Thanks.
