There was an excellent post earlier in Renntech that was about a Cayenne leaking water in the storage area and the culprit was that the drain connector came loose and needed to be re-sealed with silicon
http://www.renntech.org/forums/index.php?s...8&hl==11709
My isssue is that the same thing happened to my 2004CCT but it is leaking in the front passenger foot well. Does anyone know how to get to the drain in the front passenger side of the following picture?
http://www.renntech.org/forums/index.php?a...st&id=11709
Also before I go to the drain, the footwell was soaking wet after driving in pouring rain for 40 minutes and another time in a car wash. Would that much water come from these drains?
Thanks in advance - Steve
Also - Thanks for the heads up with the Durametric recommendation. Bought one last month and it came in very handy in debugging a rough engine problem (Bad coils - which ended up getting repaired under CPO warrantee)
