Broke control arm linkage on 00 C4. In the process of replacing it but unsure of the correct torque. Does anyone have the numbers or is there a site that has the settings? thanks
74 lbs to the cross member, 56lbs to the wheel carrier. As a note, the service manual says there are two styles of control arms, and both the control arms on a car must be of the same style.
location Thread Tightening torque
Nm (ftlb.)
Carrier side section/cross member
Carrier side section to body M12 x 1.5 110 (81)
Studs for carrier side section to
body only screw-in torque M12 x 1.5 46 (34)
Cross member at rear
to carrier side section M12 x 1.5 110(81)
Cross member at front to carrier
side section M10 x 1.5 65 (48)
Brake hose holder to
carrier side section M6 10 (7.5)
Diagonal brace to body M10 x 1.5 65 (48)
Diagonal brace to cross member M12 x 1.5 110 (81)
Diagonal brace to carrier side section
(collar nut) M10 x 1.5 23 (17)
Axle strut
Control arm 2 (toe controlarm)
to wheel carrier M12 x 1.5 75 (56)
to cross member (toe eccentric) M12 x 1.5 100 (74)
Control arm (lower control arm)
to carrier side section (camber eccentric) M12 x 1.5 100 (74)
Diagonal control arm
to control arm M14 x 1.5 160 (118)
to carrier side section M14 x 1.5 180 (133)
Control arm 3 and control arm 4
(upper control arms)
to carrier side section M12 x 1.5 110 (81)
to wheel carrier M12 x 1.5 110 (81)
Note
When replacing tie rods, pay close attention to
the correct allocation.
Install only identical tie rods - version A or
B ~ on a vehicle.
For a detailed explanation - distinguishing
characteristics and Part No. - refer to "Tierod
replacement" (after installation).
Tie rod replacement
Only tie rods with harder rubber mounts
(optimised tie rods with spherical mounts) -
version (8) - are still available from the Parts
Service.
Introduction of the optimised tie rods in the
current model year 1999 (X) in some cases I
but generally from model year 2000 (Y).
Part No. of the optimised tie rod:
996.331.045.10.
These tie rods may be retrofitted - but only in
pairs.
In general, the following applies: Only tie
rods (toe control arms) of the same version
- A or B - may be installed in a vehicle.
In the case of replacement, replace both
tie rods if necessary (install version B).
Visual distinguishing characteristics
between tie rod versions A and B:
The cast number (refer to Fig. 292_99 and
text below the illustration).
The metal bushing of the rubber mount.
On version A, the metal bushing of the
rubber mount is flush with the tie rod.
On version B, the metal bushing of the
rubber mount projects slightly - by approx.
1 mm - at both sides (arrow).
A - Tie rods without spherical mount
Part No. 996.331.045.06/07 /08
Cast No. 996.331.245.06/07/08
292_99
B - Tie rods with the spherical mount
(optimised tie rods with harder rubber mount).
Part No. 996.331.045.10
Cast No. * 996.331.245.10 (current)or
Cast No. '" 996.331.245.08 3 (the 3 was
stamped at the end of the cast number in order
to distinguish it (arrow) and was additionally
provided with a blue dot in this area).
On tie rod version B, the metal bushing of the
42
Sorry, I would post the diagrams, but for some reason I can only cut and paste the text from my service manual.
thanks for the info
Nm (ftlb.)
Axle strut
Note
B ~ on a vehicle.
Tie rod replacement
Service.
996.331.045.10.
pairs.
292_99
42
