I've tried to search for info on this swap, but am a little uncertain. I have read that the transmissions and cables are better on the newer cars, but I was wondering if I can just swap the soft top with frame (bows) from the later year models to the earlier without any modifications and without replacing my 98 transmissions or motor? I am considering buying a 2002 top with frame to go on my 1998 Boxster.
Carlsson:
You can do that swap without any modifications whatsoever, all in about 1 to 1 1/2 hours.
The one plus you will have is that the 2002 top comes with an inner liner, so that car is a little quieter at speed, and it looks a little more plush.
You can use the instructions for replacing the earlier OEM tops with an OEM glass-windowed top and frame assembly from an '03 or '04 for the job that you are doing. Just use the relevant sections: http://sites.google.com/site/mikefocke2/in...ndframeona%2797
Good luck! You should not have any difficulties whatsoever.
Regards, Maurice.
