Who can help me in regards to my engine check light of my '03 Boxster S - my dealership tried to fix the problem already 4 times and is lost now. Obviously a sensor detects a vacuum which leads to the gascap, but the gascap has been replaced already twice - still no success.
Who had the same problem, who has some experience how to fix it? It must be something else than the gascap.
I appreciate any hint, thanks buddies!
Michael
There is a TSB which recognized this set of codes:
P0441 (DTC 93) Tank vent system
P0455 (DTC 94) Tank vent system (major leak)
P0422 (DTC 97) Tank vent system (minor leak)
It was only supposed to be for the 98-99 Boxster.
Scott
The code is P0422 (DTC 97) tank vent system, minor leak - and now what? We're still lookin for the root cause.
I am still in need of advice, many thanks in advance!
Michael
Send me an e mail, and I will send you the TSB.
It tells you what to do... ;)
Scott
