I went down to the RoseBowl this evening and took these pictures. I thought they came out quite nice.
By the way it was 75 degrees today... :D
The wheels look even nicer in high resolution! Not normally a big fan of aftermarket wheels but you made a great choice. The fronts really fill up the wheel well, any clearance issues on tight radius turns?
BTW, its 30 degrees and snowing here on the east coast... My girl is sleeping quietly in the garage dreaming of 75 degree weather!
Cheers, GW :cheers:
very nice Philip! question, would the cold air intake harm the engine? I am thinking of having one for the sound, do you recommend it?
Hamad,
No the intake wont harm the engine. Won't void your warranty either. It just bypasses the muffler in your airbox. I diconnected the cable to my PSE so that it's on all the time. That combined with intake...It sounds soooo sweet...... :clapping: .
Cheers, GW :cheers:
Glad you like them. No there are no clearence issues. I would still like to have it a bit lower. I wish there was a way to drop it a half inch without making the ride harsh. Any suggestions?
FWIW, when I bought my 996 it was lowered by about 1.5 inches from stock (clearance measured from the suspension was ~4.5 inches instead of ~6.1). The suspension still did a good job with the bumps, however it would occasionally hit the front suspension stops on the highway on a large dip. I didn't mind the ride, however I ended up raising it back up an inch to ~5.5 because I was tired of damaging the front bumper (C4S bumper) getting into driveways. I actually pulled the bumper partially off on a particularly bad driveway. If you decide to lower I would suggest not going much lower than 5" measured from the recommended suspension points otherwise you will have to be very careful with the nose.
Although I now have noticeably more body roll than I did when it was lower. I was planning on posting a detailed history of my experiences in the near future...
Cheers, GW :cheers:
Thanks for the info! :cheers:
My only gripe with them big 20's, is that they make the 'S' rotors look like a Corolla's! ;) I'd invest in some PCCB's with the yaller calipers. I hear 2nd mortgages are cheap nowadays. . .
Phillip,
The only suggestion I have to lower would be to install the X73 Carrera Race Suspension for Turbo/C4S. It will drop the car 20mm and Suncoast Porsche has the kit listed for $2549.00. You can install them yourself or maybe have a buddy assist.
GW :jump:
Oh dear... And I thought I was done..... :huh: Maybe next year... Wait...Next year is only a couple weeks away right? :P
Seriously, that's a lot of coin to drop. But if I do decide to do anything it will only be with a factory Porsche kit.
Sorry to be such a dumb American but how does 20mm translate to inches?
Thanks for your input!!
Edited by phillipj
20mm is about 3/4 of an inch. Doesn't sound like much but you would definitely see the difference. I'm a bit of a purist so I personally wouldn't recommend any aftermarket drop kits. I prefer to stick with Porsche engineering… Plus that would put you in the same crowd as the tin can buzz bombs and I don’t think you would like that. Just my opinion!
Phillip:
WOW!!! Those wheels and those pics look stunningly BEAU-TI-FUL!!! :clapping:
Thanks for posting the hi-res photos!!!
Regards, Maurice.
Thanks Maurice! :D
I have a little shimy at 60 mph. Dealer told me that I should get the car aligned when I put on the new wheels. So that's what I will do (but not by the dealer. :P )
Phillip,
GW :jump:
Better way to go would be to install PSS10 coilovers but an issue with lowered car (PSS10 will drop it down for an inch) is a serious one - I would literally take a ruler and measure all driveways and bumps on your regular routes and think twice prior to doing it.
Coilovers together with GT3 adjustable lower control arms will make car much sportier and allow up to -3 degrees of front camber to completely eliminate understeer. Great mod, but, lowered car may become unusable for any daily routines.
