I am looking for the factory Maintenance Checklists for the 45k service on a 1995 911. Does anyone have access to them or a copy of them?
Edited by outcast911
I don't see one for 45k but here is the standard schedule for a 1995 Carrera:
911 Carrera 15,000 Mile Maintenance
1. Diagnosis System: read fault memory
2. Change engine oil (no oil filter change)
3. Check condition of all drive belts
4. Visual inspection for leaks (oils and fluids)
5. Check engine air filter and replace if necessary
6. Replace particle filters (climate control system)
7. Check tightness of hose connections (crankcase ventilation)
8. Fuel system visual inspection for leaks or damage
9. Intake air system: check hoses, lines and connections for tightness
10. Check handbrake operation and adjustment
11. Brake system: visual inspection of pads, rotors and lines
12. Clutch: check play or final position of pedal
13. Throttle valve: check for ease of movement and full throttle position
14. Resonance flap: check operation
15. Steering gear: check for leaks or damage
16. Track rod links: check for play or damage
17. Power steering: check fluid level
18. Check all suspension components for tightness or damage
19. Axle joints: visual inspection of dust boots
20. Manual transmission/axle drives: check oil level
21. Automatic transmission: check oil levels
22. Drive shafts: visual inspection for leaks or damage
23. Exhaust system: visual inspection for leaks or damage
24. Tires: check condition and pressure
25. Lubricate door hinges and rear lid hinges
26. Check door, lid locks and safety hooks on front lid for tightness and operation
27. Safety belts: check condition and operation
28. Check all electrical equipment and warning lights
29. Check headlights for alignment and operation
30. Check horn operation
31. Check ignition circuits 1 and 2 with system tester 9288
32. Road test: check brakes, parking brake, clutch, cruise control, steering, heating, AlC and instruments
911 Carrera 30,000 Miles Maintenance
These operations are to be performed along with the operations in the 15,000 mile maintenance.
1. Change oil and both oil filters
2. Replace all spark plugs
3. Change automatic transmission oil
4. Replace air filter
911 Carrera 60,000 Mile Maintenance
These operations are to be performed in addition to the 15,000 and 30,000 mile maintenances.
1. Replace fuel filter
2. Change transmission oil manual transmission
3. Change differential oil automatic transmission
